Crystalfontz LCD Forum
Go Back   Crystalfontz LCD Forum > LCD Software > CrystalControl2
Notices
Closed Thread
Thread Tools Rate Thread Display Modes
Old 2008/04/04, 07:49 AM   #1
CrystalControl Admin
Lightbulb CrystalControl2 - 03/04/2008
Note: This release of CrystalControl2 has had very limited amounts of beta testing, and it is quite likely a few bugs exist. If you have problems, please report them in the forum.
Version History:
03/04/2008:
- New rFactor plugin
12/08/2007:
- New Rivatuner plugins
- Fixed E01's in email plugin
20/07/2007:
- Tweaked timing routines.
- Many more small fixes.
25/12/2006:
- New Screen-Editor!
- Screen transition effects!
- New plugins.
- Lots of bug fixes.
25/03/2006:
- Fixed empty string INI bug.
- New kill_cc2 utility.
26/02/2006:
16/02/2006:
- Added user idle LCD dimming
- New screens
- Fixed screen loading bugs
- Added simple calc plugin
- Fixed many misc bugs
- New screens
- Manual updates
- New loadable screens
- Now supports item scrolling
- Many other smaller things
- First public release
__________________
Crystalfontz CrystalControl2 Author
CrystalControl Admin is offline
Closed Thread
Bookmarks
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.8.5
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
