Adjusting the Contrast on CFAG12864T and CFAG12864U series
Our CFAG12864T and CFAG12864U series are a great display to use in any project. You are able to adjust the contrast easily through our sample code.
Links to repository, zip file and LCD_low.cpp
GitHub repository:
https://github.com/crystalfontz/CFAG12864Tx_and_Ux_ST7565P
Zip file download:
https://github.com/crystalfontz/CFAG12864Tx_and_Ux_ST7565P/archive/refs/heads/master.zip
Exact file for contrast control:
https://github.com/crystalfontz/CFAG12864Tx_and_Ux_ST7565P/blob/master/CFAG12864Tx_and_Ux_Arduino/LCD_low.cpp
Location of contrast control value
In this example, I’m working in the Arduino code in LCD_low.cpp, which supports the CFAG12864T3, CFAG12864T4, CFAG12864U3, and CFAG12864U4.
First, select the display you’re using in LCD_low.h (lines 38–41). Then find the contrast setting for your display in LCD_low.cpp:
For CFAG12864T3 line 208
For CFAG12864T4 line 218
For CFAG12864U3 line 228
For CFAG12864U4 line 238
The contrast range is 0–63, and the default value is a good starting point. Increase the value to darken the display, or decrease it to lighten it. The U3 section is shown below as an example.
#if (display_type == CFAG12864U3)
  //Set the resistor ratio range (0-7) so that the contrast is near
  //the middle of its 0-63 range.
  SPI_sendCommand(NT7534_20_RESISTOR_RATIO_RANGE_SET_BIT | 0x04);
  //The contrast has a range of 0-63.
  //For the CFAG12864U3 Contrast of 24 looks pretty good.
  SPI_sendCommand(NT7534_81_CONTRAST_PREFIX);
  SPI_sendCommand(24);
#endif
